4440 fuses
musicman44
11-17-2006 14:05:30
This may seem dumb, but I can't seem to find the fuses for lights on a 4440.
Bob
11-17-2006 14:13:44
 Re: 4440 fuses in reply to musicman44, 11-17-2006 14:05:30
The CIRCUIT BREAKERS for the lights are under the LH dash cowl panel, just ahead of your left shin.
Deere had trouble with the buss bars and the insulated platform the breakers mount to on those tractors.
The plastic deforms with heat and time making for a poor connection, which further overheats the plastic, causing a total failure ot the breaker making connection with the buss bar.
Also, there are relays directly underneath the steering column for the high and low beams that sometimes fail.
musicman44
11-17-2006 20:20:28
 Re: 4440 fuses in reply to Bob, 11-17-2006 14:13:44
Thanks, Bob.
I have a wiring diagram copied out of a service manual that shows actual fuses. It must be for something older. I'll check the breakers as you said.
