Engine oil capacity in a 48-A?
Sam S.
11-16-2006 19:16:40
I have found two different sources, one specs. a 48-A engine at 9.2 qts and the manual says 11 qts.
The side petcock will spit oil out at 8-9 quarts, so what is a safe level and how do you check it?
Thanks,
Sam
James Howell
11-17-2006 07:51:44
 Re: Engine oil capacity in a 48-A? in reply to Sam S., 11-16-2006 19:16:40
Sam,
Duane is correct. Open the oil level test cock and continue to add oil until it starts to drip out. Close the oil level test cock.
Start your 48A and let it run awhile. Shut it down and check the level again. Add oil if necessary.
I will be changing fluids on my favorite wife's 48A this weekend. Will make sure I have at least 11 quarts available as suggested by the manual.
Duane Larson
11-16-2006 21:25:44
Sam,
I would go with the owner's manual directions, which says to fill until it runs out the oil level test cock. The manual also lists capacity as 11 quarts, including the filter volume, which is a useful guide only when going out to buy oil, in my opinion.
