jdemaris
11-17-2006 06:26:38
40 series problems when new in reply to MSM, 11-17-2006 01:36:44
When the 40 series ag. tractors came out - we were already well aware of valve-depth problems with Deere direct-injected diesels. It was common knowledge for the yellow engines, but not so much for the green. Typical case of one division not talking to the other? Deere also claimed there were assembly and communication problems between US engineers and those in Germany, where many 40-series engines were made. In some ways, this got worse with the 50s (engines got better, drive-train worse). We had been putting all Deere valves at .020" and .040" for years - on yellow hoes, dozers, skidders, etc. When we started having many smoking and starting problems with new 40 series tractors - Deere came up with the following (and perhaps more): Different thickness head gaskets, different pistons with varying standouts - each marked and graded, valve depth changes, fuel timing static advance changes, new tranfer pump blades and liner in the injection pump, hydraulic pump destrokers, etc. Some of these band-aids worked on some tractors, some tractors NONE of them worked. The reality was - very sloppy and wide tolerances in engine assembly. Every part had an allowable plus or minus. So, no two engines were ever exactly alike. We complained at the time, that if we started using all these different pistons, gaskets, etc. - what will happen the next time some poor guy tries to rebuild the engine? How will he/she know what to use? It was shortly after, Deere came up with a sort-of universal, backwards compatible fix - I forget exactly what. But gaskets got standardized, and the pistons had a higher head and a higher top ring groove. When the 50s came out - they started much better than the 40s. But - the first 30 or so 4WD tractors we got in - ALL had a miss-match of gears - and the front wheels turned much faster than the rear. They would tear up a field real fast. Deere once again - blamed most of the problem on Germany - and we had to pull them all apart under warranty.
