'49 JD D petcocks
Loy Stewart
11-15-2006 13:29:36
Where can I find the petcocks with the priming cups. I have one bad on this D. Thanks, Loy.
Skyhawk Greg
11-16-2006 10:13:04
 Re: '49 JD D petcocks in reply to Loy Stewart, 11-15-2006 13:29:36
Loy, These are very common on E-bay.
JAS
11-16-2006 09:43:31
You shouldn't need ones with priming cups. That style was used earlier when the carbs weren't as good. I've got a 48 D and there is no reason to prime it. My wife will even start it stone cold. And no, not by turning the key! And No, she's not an ox. Everthing is just right.
Anderson
11-15-2006 17:52:44
Try Kim Johnson out of Minnesota. His has alot of used two-cylinder parts. He should have a good used one for you. 218-729-7143.
Loy Stewart
11-15-2006 18:08:20
 Re: '49 JD D petcocks in reply to Anderson, 11-15-2006 17:52:44
Thanks a bunch. Loy.
