1939 B JOHN DEER
herb Brady
11-15-2006 11:59:44
I just recently purchased this tractor. No electric, sheet metal is in good condition, has been repainted and is good enough for daily use,but not show quality. also has brand new tires frnt and rear Runs good with no smoke and pulls well. The hyd. lift doesnt seem to work. But every thing else does. It also has a boehln overdrive in it which gives it a 5th & 6th gear. Really fast in high gear and the frnt end has no wobble or play in it. runs real straight in high wide open. Were many of these overdrives made, I had never seen one before. IM not sure I spelled ovredrive name right. Herb Brady
Herb Brady
11-15-2006 17:54:41
 Re: 1939 B JOHN DEER in reply to herb Brady, 11-15-2006 11:59:44
Dick Stan On my tractor they put a spacer behind the flywheel to give it clearance for fingers, works fine havent scraped fingers yet.
My reservoir was empty put in some oil but didnt have enough at the time to fill it, hope that all it is when I get more oil
Stan - Florida
11-15-2006 18:44:45
 Re: 1939 B JOHN DEER in reply to Herb Brady, 11-15-2006 17:54:41
Herb,
Keep us posted on the results, please.
Good luck,
Stan
Geoff Mathews
11-15-2006 13:39:08
My 39 B hydraulics never worked from 1944 till 1986 when I put some oil in - now they are fine
Mike M
11-15-2006 13:09:02
I have seen alot more of those gear box overdrives than the Baker valves for the hyd.
Those gear boxes were not easy add on as you also had to remove the tran. shafts and install different ones. So incase you had maybe thought of taking it off I wouldn't bother.
DickD
11-15-2006 12:19:46
We had a 39"B" we farmed with that my father had a Behlen Gearbox installed. They weren't that uncommon. If my memory serves me right, I think Behlen made cribs and several other farm oriented pieces. Outside of being a real finger masher when starting the tractor, the gearbox worked very well.
Stan - Florida
11-15-2006 12:04:10
Can't comment on the Spelling of Behlen, but this looks right (I hope). Not common, I don't think, but not unusual enough to be considered "rare".
Regarding the hydraulic not working...did you engage the PTO? That's necessary to run the hydraulic "Power Lift".
Stan
