Converting a G model
txasylum
11-15-2006 11:45:54
This is a carryover from a previous post, but now I am asking a different question.
What does it take to convert a G model from LP back to gas?
Bob
Glen in TX
11-15-2006 12:57:51
 Re: Converting a G model in reply to txasylum, 11-15-2006 11:45:54
Nothing but money, parts and elbow grease lol. A gas tank and hood usually and anything else like brackets that got butchered up putting the aftermarket LP setup on. Might also need a carb if it's a true LP carb on there now but most just had a vapor tube stuck in top of original gasoline carb to convert it on JDs and you can switch it back to gasoline and rebuild the carb and plug top hole. Many people just like to leave the aftermarket LP setup on it and restore it as an example like it is. I've seen some put a vented cap on LP tank and put gasoline in it too but I don't know why you want to do that. It may also depend on if parts are available at all for the aftermarket LP converter/regulator.
txasylum
11-15-2006 13:07:08
 Re: Converting a G model in reply to Glen in TX, 11-15-2006 12:57:51
From the previous emails, it looks like the tractor would be worth more if it was in its original condition. But it might take too much to bother with it. I plan on reselling after doing some restoration (partial or full) on it.
Glen in TX
11-15-2006 13:25:31
 Re: Converting a G model in reply to txasylum, 11-15-2006 13:07:08
It will just depend on what condition you find it in then. Many parts are available for Enco or Century LP equipment but some of the others like Ensign or no longer made odd brands can be harder to find parts for if at all. It probably has been converted with higher compression pistons for LP too and it will run better on gasoline with those.
