What I did to my G clutch, DOUBLE DISC IT
Ben.So.Tex.
11-15-2006 08:08:38
I put a complete new clutch in my 49 G, about year and a half ago. And now after adjusting it a few times, about 3 times, I have run out of bolt tread...
So I took an old clutch disc liner and installed it with the outside one (Double them) and it now it has tread for adjustment. It snap good.( I got my clutch from our local JD dealer, not an after market ) What type of problems could I have by doing this?
Thanks Ben
JLG
11-15-2006 12:26:04
 Re: What I did to my G clutch, DOUBLE DISC IT in reply to Ben.So.Tex., 11-15-2006 08:08:38
I had just about the same thing happen when I put a new clutch in my "G". Except mine was too loose from the start and I used parts from a good aftermarket supplier. I finally compared the old parts to the new ones. On the new set, the double faced disk that slides over the bolts (part #AD1027R if you have a parts book) was considerably thinner. I needed the tractor so I did the same thing you did to make up the difference and haven't had any trouble the last year. Although now that I read some of these other posts I'm going to pull the clutch cover off and check everything out!
machinery-man
11-15-2006 11:24:48
There is an underlying problem but wouldn't installing some solid thick washers under the nuts have done the same trick? There is a problem with wear and like other post the driver may be loose. I would not put any additional items in the assy as you could be heading for a shipwreck if the clutch doesn't release. John Deere was always paticular concerning the inside assy as all it would take would be a large piece of debrie to hang the clutch and shutting down that baby would be difficult. The governor can go from idle to full throttle without any problem. Be safe rather than sorry.
Gwiz
11-15-2006 17:46:10
 Re: What I did to my G clutch, DOUBLE DISC IT in reply to machinery-man, 11-15-2006 11:24:48
My 'aftermarket' supplier ships the washers and says JD has been recommending them for years to help the clutch snap into place. ?? James
Mike M
11-16-2006 11:29:02
 Re: What I did to my G clutch, DOUBLE DISC IT in reply to Gwiz, 11-15-2006 17:46:10
There are some washers listed in the later 2 cyl. parts books (like 730) that are slightly cupped shaped (belvue) suspose to help with jumpy clutches ?
Mike M
11-15-2006 10:03:35
I would be concerned about that extra disc dropping out of position and jambing up everything causing you to not get stopped.
There has to be an underlaying problem causing this condition.
john deere 70
11-15-2006 09:59:10
check the bolt in the center of the crank that holds the clutch driver on to make sure it is not loose.
F-I-T
11-15-2006 08:44:56
Ben:
It will sure work that way, but I think you might have a deeper problem if you ran out of thread on the "Tee" bolts after just a few times. I would guess that you have wear on the toggle ears and the T-bolt shoulders.
Frank
