Fuel gage... good or bad?
Steve
12-20-1999 06:13:27
My fuel gage on my 2010 gas only reads 1/4 full no matter how much fuel is in the tank. This weekend I took the hood off and grounded the sending wire and the gage went right up to full. Does this mean the gage is bad or the sending unit? Thank you, Steve.
Dan
12-20-1999 06:34:44
 Re: Fuel gage... good or bad? in reply to Steve, 12-20-1999 06:13:27
If you remove the ground the gauge should show above full. If you remove the sender wire it should go to empty. If you ground the sender wire as you did lt should go to full. I would say the sender is bad. It looks as though the fuel gauge is trying to work for you
