JD 40 sounds different lately
TByrd
11-14-2006 16:47:22
I have a 1954 JD 40S. Last year the engine was rebuilt by a reputable machine shop, bored, rebuilt oil pump, etc. I also replaced the head with a new Chinese-built unit. Ran great, but lately, it sounds different and seems slow to speed up. Sounds like something bubbling in the exhaust sometimes. I also notice a little oil leaking from the front of intake/exhaust manifold. I plan to remove the valve cover to look around and check valve clearances, etc. I may remove the manifold to have a look. I was hoping to field some suggestions before doing anything.
TByrd
11-16-2006 07:38:50
 Re: JD 40 sounds different lately in reply to TByrd, 11-14-2006 16:47:22
Autolite plugs, I believe the number is 80 but could be mistaken. Yes, I replace the distributer shaft bushing. Remember, it ran great at first; however, if the front cylinder was not firing properly on each cycle, that would build up uncombusted fuel and could seep from the manifold and cause the sound change I mentioned. I will check the basics this weekend and post results. thanks.
buickanddeere
11-15-2006 09:15:18
Try pulling a plug wire and see how she runs on one cylinder. That should narrow down which cylinder or perhapes an ignition problem. Did you install a new bushing in the dist? Did you have the cam and cam followers re-ground? What kind of plugs and plug wires?
