4440 Lost Reverse Quad Range Trans
oak
11-14-2006 16:02:51
4440 lost Reverse Has Quad Range . Seams to shift into gear but I hear grinding when letting out clutch all other Gears and Ranges work great. any Ideas. Also can 4440 be split at Clutch housing and Trans Housing, to get into Gear Trans? Thanks in advance
msb
11-14-2006 20:11:33
 Re: 4440 Lost Reverse Quad Range Trans in reply to oak, 11-14-2006 16:02:51
I would try adjusting the linkage first before I split the tractor.
Brad the JD Tech
11-14-2006 18:59:27
There is a good chance the bearings went out of the trans or the reverse gear broke and fell down in the bottom of the trans. On a 40 series you can split the tractor at trans to get to the gears. You dont have to spit it at the clutch houseing unless you want to. I would and i would check the clutch and quad range packs.
