Air Cleaner Indicator - 4430
Tom Luoma
11-14-2006 10:13:34
The 4430 has an Air Cleaner Indicator on the instrument planel. Can anyone tell me where the sender/sensor for this warning lamp is located?
Glen in TX
11-14-2006 12:41:24
 Re: Air Cleaner Indicator - 4430 in reply to Tom Luoma, 11-14-2006 10:13:34
It's under the hood on the piping to turbo intake someplace. If the light is on pull the wire off as they don't work anyway most times and just do your job more often of cleaning the filter.
Tom Luoma
11-19-2006 09:42:53
 Re[2]: Air Cleaner Indicator - 4430 in reply to Glen in TX, 11-14-2006 12:41:24
Thanks for the help. It is on the air pipe, right side, near the front of the engine.
The connection on the sensor is broken off. I was looking because I wasn't getting a light on startup.
I can see why they aren't reliable -- it is a simple vacuum sensor. 1973 tech is not up to the task.
As much as I like JD their manuals leave much to be desired.
Glen in TX
11-14-2006 12:55:09
 Re: Air Cleaner Indicator - 4430 in reply to Glen in TX, 11-14-2006 12:41:24
See JD parts catalog
