Can any one help with a 1530 starting problem???
Kevin Woodruff
11-14-2006 07:24:17
This really has me stumped. When I try to start my 1530 the solenoid clanks, and the starter spins but it dose not turn the engine over. I will turn the key on and off and go threw this up wards of ten times, then all of a sudden it turns the engine over and starts. The real stumper is that it only dose this on the first start of the day. I can shut it off and restart it 50 times in the day and it will work every time after the first start. I changed the solenoid, with no improvement. Took the starter apart and checked the Bendix. The sprag clutch seams fine and it slides freely on the shaft. And both the ring gear and the starter gear are like new. I am really stumped. I sure could use some ideas. Thanks for any help!!!
Mike M
11-14-2006 07:59:29
 Re: Can any one help with a 1530 starting problem? in reply to Kevin Woodruff, 11-14-2006 07:24:17
Sounds like I'd try another starter drive. They usually come and go. A couple of even weirder things can be a ring gear slipping. You can pull the starter and put an index mark on the flywheel and the gear and remount the starter and try again and see if the marks moved. Or I even had an armature spin on the shaft. Probabaly real rare ? but it happened to a freshly rebuilt starter causing me alot of greif. I'd still try the drive first.And while I had it apart throw in some brushes and bushings too.
Kevin Woodruff
11-14-2006 13:55:32
 Re: Can any one help with a 1530 starting problem? in reply to Mike M, 11-14-2006 07:59:29
Thanks Mike. Sure seems weird to only happen on the first start of the day. Luckily I am pretty sure the ring gear is not slipping. I have held the key till the starter is spinning up real fast, and it defiantly is not engaging anything. Off all the tractors I have had this is the oddest thing I have ever run across. Really driving me bonkers. Not to mention a real pain to take the starter on and off. I have to remove the fuel pump to do it. Thanks for the ideas. I will have to try another starter drive.
