J.D. Serial #
cdj
11-13-2006 15:31:11
Just want to confirm that serial number 14324
means that this tractor is a 1945 "G".This tractor has rubber rear tires on round spoke wheels. Could this wheels be from an earlier model "G"? What is the difference between the unstyled and styled "G" tractors? I'm not a John Deere collector just happened to come across this one and it caught my eye. Thanks for any replies to this Curtis
DickD
11-14-2006 05:05:26
 Re: J.D. Serial # in reply to cdj, 11-13-2006 15:31:11
Check the tire size. If the wheels are spoke there is a chance they might be 36in. tires if the wheels are off an earlier model G. Using them would slow your ground speed down.
cdj
11-13-2006 16:29:49
Thanks alot for the info. Curtis
Glen in TX
11-13-2006 15:55:27
Look for F&H and some numbers on your wheels. Someone like Duane Larson the wheel expert could then tell what they were for or if from something earlier.
Gary from Muleshoe
11-13-2006 15:49:17
Yes that would make it a 1945. I believe some of the G's still came out with spoke wheels until mid 40's. The unstyled JD's had the seering post exposed as well as the radiatorand shutters. The styled hood covered all this. Go to this site for more infomation on JD serial numbers Link
The>Link home page of this site shows an unstyled JD GP tractor.
This site will give some general info on a G.
Link
Shows both the styled and unstyled models.
