How not to Poof
F-I-T
11-12-2006 15:26:12
If you try to solder a fuel tank without de-gassing it first, you're probably going to get a "poof" or worse. To avoid any of that, wash the tank inside two or three times at least with a good quality alkali cleaner like Simple Green, Kelite, or Purple Cleaner until it make suds consistently. Then, the secret weapon, go buy a can of spray brake cleaner that says it contains Perchlorethylene. This is the aromatic solvent that was used as a dry cleaner solvent for years, and it is NOT FLAMMABLE. In fact, it is the main ingredient in those $1 spray can fire extinguishers that we all used to keep in the combine tool box. Test it by spraying a spurt at a candle or a burning leaf. It will kill the flame right on the spot. The vapor is also heavier than air.
Now take your clean tank, with most of the water drained out of it and put a cork in the bottom and spray a good healthy amount into the tank. As it warms to room temperature, any flammable fumes (and there should not be any left after the thorough washing) will be pushed out the top as the "Prec" boils to a gas. Do this in a windy free area. Now you can solder it and it will never "poof". Much more dependable than car exhaust.
A few cubes of dry ice will also work, but it is not as effective in pushing the fumes out since "Perc" is so much more dense.
Frank
