48A Connecting Rod Lubrication?
Sam S.
11-11-2006 05:27:22
My 48A had a hot Connecting Rod Bearing on the left side, so I am totally reduilding her.
Question is, how does the Connecting Rod journals on the crankshaft get lubrication? I don't see any cross drilled holes in the crankshaft, so is it splash lubrication?
Thanks,
Sam
Mike M
11-11-2006 11:34:48
 Re: 48A Connecting Rod Lubrication? in reply to Sam S., 11-11-2006 05:27:22
The rod journals get their oil from a cross drill hole into the mains. Yours must be plugged up ?
HaroldIHC
11-11-2006 07:34:34
Sam, I just replaced the crank and rods in my 48 A for the same reason as you are. The rods are lubed from pipes leading from the oil pump to the main bearings on each side. Make sure these lines are clean. Test by rotating crank with starter before installing rods. Watch for oil spurting from crank journals. Plugged or broken line may have been the reason your bearing fried. Hope this helps. ----- ---Harold
Sam S.
11-11-2006 19:52:06
 Re: 48A Connecting Rod Lubrication? in reply to HaroldIHC, 11-11-2006 07:34:34
HaroldIHC,
That is a great idea to pressurize the oil system, befor ethe rods are attached. I may do that again after the rocker arms are installed, to make sure oil is getting at the front end too.
Thanks,
Sam
Lee B
11-11-2006 21:02:54
 Re: 48A Connecting Rod Lubrication? in reply to Sam S., 11-11-2006 19:52:06
'Cross drill' means literally to cross a single journal with a drilled hole so that oil supply is not interupted by such setups as a single grooved main bearing shell as found on some early chevy big blocks for example. The term does NOT apply to JD two lungers so a cease and desist order for the above quoted term's use IS pending.
Rocker arm oil supply is intermitent by design. IIRC, a pass thru hole in the oil pump drive rod prevents full flow to the rocker arms, just further FYI.
Mike M
11-12-2006 06:08:31
 Re: 48A Connecting Rod Lubrication? in reply to Lee B, 11-11-2006 21:02:54
WHAT !!!!
Those crankshafts are drilled !!!! How else are you going to put oil pressure to the rod journals.
And I don't recall any holes in the oil pump driveshafts ????
