JD 430t
HDJD
11-10-2006 10:17:39
I have a JD430T that I have owned for 20 years(I bought it from the original owner). It has been sitting in my garage for a couple of years. I recently tried to start it and the motor is stuck. It ran when I parked it. You can't turn it over with the hand crank. No water got in as the exhaust exits out down, not up as original. I have put Marvel Mystery Oil in it and it still won't turn. Any suggestion or tips would be greatly appreciated. Thanks in advance fo your help.
WV2cyl
11-11-2006 16:53:49
 Re: JD 430t in reply to HDJD, 11-10-2006 10:17:39
Give it a ride. I bought a B Deere at one of the Indiana sales that was stuck. I pulled it on the trailer, put some Marvel Oil in the cylinders, allowed some slack in the chains, put it in high gear and hauled it 600 miles home. It was free and we started it later. I had a 40 that was stuck as yours and I loaded it on the trailer and drove about 100 miles on business and when I returned home it was free also.
Harlan Kruger
11-10-2006 18:28:49
Usually the easiest and cheapest way is soaking the cylinders is some type of penetrating oil. Which may get the pistons free, but you may have stuck rings on free pistons. Not sure how I feel about the rocking or pulling of it in gear to get it freed up, that can result in broken connecting rods or other damage. Rocking it probably isnt enough force to break something. If it was my tractor I would do a complete tear down and restore it. Then you know what you have and what has been done to it, It will be worth that much more and you will get more life out if it just my 2 cents
El Toro
11-10-2006 17:16:50
I agree with Henry on the ATF. That's how I freed up one of those red ones. You need to be patient. Hal
Henry M
11-10-2006 16:40:27
Up the antie and put about 1 oz of tranny fluid in each spark hole.
Put it in 5th gear and at least once a day when you walk by it, grab a rear wheel and rock it back and forth to the tune of about one man power.
Let us know either way.
good luck
ps if you have access to kryoil, put one oz of that in there also.
Mike M
11-10-2006 10:36:36
Sometimes the starter drive gets caught and if you can turn the engine over backwards it releases. If the cylinders are stuck let them soak and try rocking it in gear.
CPeter
11-11-2006 07:13:02
 Re: JD 430t in reply to Mike M, 11-10-2006 10:36:36
Try taking the starter out and making sure it is not jammed. They are famous for the bendix hanging up and trying to turn the engine with the crank just makes that worse.
CPeter
