Cast Iron D1943R breather body ??
Glen in TX
11-09-2006 17:28:06
Cast iron breather body D1943R with 1 1/2" pipe threads looks similar to pressed metal AD918R breather body used on a JD D. What was the cast iron one used on? Thanks.
jas
11-10-2006 16:26:08
 Re: Cast Iron D1943R breather body ?? in reply to Glen in TX, 11-09-2006 17:28:06
Hey, IF it is off early styled A, I'll go check my 39 and see if the numbers match.
Glen in TX
11-12-2006 11:32:22
 Re: Cast Iron D1943R breather body ?? in reply to jas, 11-10-2006 16:26:08
If you have a cast breather body on a tractor yeah check numbers on it. This number is not listed in A parts catalogs I have either.
Bob Bedlan
11-09-2006 18:49:53
My D parts book shows this No. as felt washer,governor shaft,R.H.
Glen in TX
11-09-2006 19:15:37
 OOPS... D1948R cast breather in reply to Bob Bedlan, 11-09-2006 18:49:53
Sorry Bob wrong number. It's cast iron and D1948R is number in casting.
Glen in TX
11-09-2006 19:52:50
 D1948R Pic in reply to Glen in TX, 11-09-2006 19:15:37
third party image
Posted a pic of it. Early D or something else?
Bobl1958
11-10-2006 07:02:40
 Re: D1948R Pic in reply to Glen in TX, 11-09-2006 19:52:50
Didn't some of the early styled A's have a cast breather? Just shooting in the dark. I've had D's from 27 and newer and don't remember one having one, but could have been special too. Bob
Glen in TX
11-10-2006 09:44:53
 Re: D1948R Pic in reply to Bobl1958, 11-10-2006 07:02:40
AA360R is the breather body shown in my unstyled A parts book and for earlier styled A also. Later As had ventilator pump on fan shaft by governor. I'm pretty sure it came off one of the parts Ds we salvaged years ago but I didn't keep up with which year it came off of. Maybe 28, 29 or 30? Casting number fits the D parts numbering system and looks like the welded pressed metal but is solid cast body including the pipe part also. No mention of it in any of my D parts books but was hoping someone had early original parts book and would see it and tell me. Kind of remember reading something about it once in a JD history book about some Ds going for export or Russia in 29 or 30 that may have had cast breathers and some other parts on them before the breather came standard on 1931 Ds and up. Earlier Ds before 31 didn't have breathers on them. We never parted out any exhibit A or B model Ds either because I kept records of the Ds we parted out for scrap years ago and left the serial number tags on trans cases when they went for scrap but most of those were styled Ds we only bought for engines and parts that salvage yard had already stripped half down. Just wondering if someone with a exhibit A or B changes on model D has this type breather on it or has seen one? Thanks.
