G JD
Les X.
11-09-2006 08:10:52
with a short styled block, flat head and high comp. piston what kind of Comp. am I looking at? Horsepower ideas with this combo?
2 Cylinder
11-09-2006 18:39:02
 Re: G JD in reply to Les X., 11-09-2006 08:10:52
Not quite sure what kind of compression it has, but I am running the styled block, flat head, .090 over high compression pistons with the baffles ground out of the manifold on my 51-G. It dyno"s 68 horsepower, but needs high octane gas. Suggest adjusting the timing while on the dyno to achieve maximum horsepower on the dyno. I use mine only for antique tractorpulling with 16.9 x 38"s in 5500 lb. through 7000 lb. classes with plenty of power.
G father
11-09-2006 14:11:42
Your looking between 210-230 cranking compression on each cylinder!
