HARD SHIFTING 4520
SDJJ
11-09-2006 06:48:19
my friend just got a 69 4520. the tractor goes into gear really hard. the linkage is very free. any ideas?
Mike w J
11-10-2006 20:05:11
 Re: HARD SHIFTING 4520 in reply to SDJJ, 11-09-2006 06:48:19
I had a 4620 it needed a clutch replaced John Deere offered a heavy duty. They called it a perma clutch Dry but suppose to be as good as The wet clutch in the 4440 tractors . It was very good for pulling They did not slip and are a SOB to shift . It would not shift faster then an idle I even broke the shift lever . But the dealer told me to put in 8TH gear foot on brakes and slip just a little and it would shift . He was right. I had good free travel and still had to slip it about 1 time a week I put 3000 hours on it and never had to adjust the free travel even after I had to slip it . That clutch Did not stink when slipped like the original ones do when they slip. John deere only made this clutch for a few years Then quit because of shifting problems.
jdjerry
11-10-2006 05:47:42
Check to see if there is any adjustment left in the clutch. My 4520 shifts harder than my 4020 and 4010. The shift lever is twice as long on the 4520 and I asume the gears and shafts in the tranny are larger.
Mike M
11-09-2006 07:29:24
Is it worse at higher engine rpm and better at idle ? If so I'd say clutch is dragging.Had that problem on our 4020 and had some warped clutch plates.
SDJJ
11-09-2006 12:03:16
 Re: HARD SHIFTING 4520 in reply to Mike M, 11-09-2006 07:29:24
DOESN'T MATTER IDLE OR FAST IDLE. WHEN TRYING TO GET IN GEAR THE TRACTOR TENDS TO TRY TO MOVE BEFORE IT IS IN GEAR.
msb
11-09-2006 19:16:39
 Re: HARD SHIFTING 4520 in reply to SDJJ, 11-09-2006 12:03:16
There is your answer. The clutch is not fully disengaging the transmission input shaft.Could be an operating finger is way out of adjustment.Could also be a bad pilot bearing.At any rate the tractor will have to be split to determine the cause.
