Hydraulic line problem on JD620
POP
11-08-2006 18:43:09
The steel hydraulic line that runs next to the battery box/seat has a pin- hole leak. I will check with mother Deere tomorrow but I feel they are out of production by about thirty years. I was thinking about trying JB-weld over the hole? Or look for a salvage yard part. What other methods have you JD doctors used? Thanks Pop
55 50
11-09-2006 13:52:20
 Re: Hydraulic line problem on JD620 in reply to POP, 11-08-2006 18:43:09
As F I T said the moist dirt will cause rust and eventually those lines will rust. Too bad John Deere didn"t say in their manuals that it would be a good preventive maintenance task to remove that platform and clean under it good about once a year. Anyone buying one of those style of tractors today would be wise to remove that platform and clean good and inspect those lines before they spring a leak. Maybe some of the "future" leaks could be prevented that way.
RLA
11-09-2006 11:34:09
I had the same thing happen last summer, went to my local Deere Shop & they had both instock to my surprise. So I bought them both. That was at Elder"s Sales & Service Sandy Lake Pa.
F-I-T
11-08-2006 20:38:57
I don't know which line runs near the battery box, but the smaller of the two is the pressure line, and that one you most likely cannot epoxy. I have cleaned the larger, suction line down to bare metal, applied JB weld, primed, painted, and it has been holding well for years. Pin holes came from years of moist dirt under the floor pan on my 70D. Since it only routes oil to be returned back to the pump, it doesn't have to resist much, if any pressure. It's basically just a drain.
You 620 lines are listed as still available at JDParts.com , either one priced at around $110.00. The pressure line is AA 7027 R, and the suction line is AA 6547 R.
Looks like you got lucky.
matthies
11-08-2006 19:46:50
I was just at Deere for the front line (2 piece) for a 60 and was available for $100. One trick I have seen and used is to clean area good and wrap clean nongalvanized baling/mechanics wire over bad spot and braze over whole area. chris
