4010 overhaul
c.r
11-08-2006 16:24:34
I have a 4010 tractor that i installed the 0versized 404 sleeves and pistons in and my question is, does just puting in the larger pistons bring the horsepower up to a 4020's 94 h.p or does the injector pump need to be turned up or modifed some other way and does the old intake system allow enough air into the engine.(volumetric efficency) to burn the extra fuel. I just bought this tractor recently and i want to make sure i have the injector pump timed to the engine properly for the model # since i see a lot of posts on here that talk about the pump being modified ie. speed and load advances. My pump model # is dbgvc631-4af 3cb the last 3 digits are hard to read so they may be wrong. Any help would be greatly apreciated . thanks chris from n.y
jack-Iowa
11-09-2006 06:04:23
 Re: 4010 overhaul in reply to c.r, 11-08-2006 16:24:34
I had my 4010 overhauled with the kit that is the same for the 4020 and when they got done and dynoed it was at 104 hp. as far as I know and they did not mention that they turned anything up. They were a little suprised by that and me what do I know.
msb
11-08-2006 18:12:29
If memory serves me correct the 4010 test stand specs call for 60 CCs per thousand strokes and the 4020 66 CCs per thousand strokes.Maybe JDMARIS can varify this.If that is the case the 4010 pump output should be increased 10% or about 1/8 turn on the leaf spring.Your best bet is to have the tractor checked out on a dynomometer as it may already be set up. Your other questions should cause you no concern.The timing will depend on which governor weight retainer the pump may have in it.And I don't remember which your pump has with the numbers you list.
