435 PS worm gear thrust bearing source ?
Just Plain Joe
11-08-2006 15:54:15
I'm posting this second hand so here goes. In a 435 with the hydraulic power split between the power steering and the 3-point system, there is a worm gear/shaft in the steering box assembly that has a ball-bearing thrust washer setup at each end of the worm gear. Sound familiar so far? OK, the outer ends (or bearing races I guess they would be called) need replacing but apparently they are no longer available from John Deere. Is there ANY replacement part available from ANY application that some of you JD guys might know of that can be used? Or any suggestion as to a substitution type fix that maybe somebody has come up with. I think the worm gear is useable but these balls and races definitely need replacing. Thanks in advance.
8e3k0
11-09-2006 07:31:20
 Re: 435 PS worm gear thrust bearing source ? in reply to Just Plain Joe, 11-08-2006 15:54:15
All power steering components are the same except the power steering pump itself and lines to and from the pump. The Detroit uses a combination power steering hydraulic pump with power steering and the manual steering pump is also belt driven that feeds the hydraulics only. On the power steering models the 430 late serial is the same as the 435 which includes the rack and pinion assembly, power steering control valve assembly,and the power steering gear and support (the M2573T Worm and the AM3976T lever shaft assembly) On the worn itself there are two bearings M932T Cup and R26552R ball bearing 22 used. These bearings are adjusted by shims under AM3669T cover. The pumps and lines are different between the two models. The parts books gives good detail on similar and disimilar parts. Hope this helps or partially answers your question. Ellis
Henry M
11-09-2006 05:15:31
Joe
Getting all the information second hand could lead to a misunderstanding. I just thummed in the 420/430 book a little and found the race to be the same for the different models. The 435 is spose to be the same in the front steering column respect.
The number that you want is probably M 932 T. But I donno for sure.
buickanddeere
11-08-2006 16:35:16
Never tell the salvage yard staff you are lookig for 435 parts if the part is identical to what is also used on a 40,420,430,440,320,330. The P.S. parts in the proper serial number range of the gassers and industrial should be mostly identical.
Just Plain Joe
11-08-2006 17:18:40
 Re: 435 PS worm gear thrust bearing source ? in reply to buickanddeere, 11-08-2006 16:35:16
So you're telling me that the PS parts for those other models that you listed are in fact the same part? And also, what serial number range are you referring to? Thanks ..... JPJ
buickanddeere
11-09-2006 19:07:22
 Re: 435 PS worm gear thrust bearing source ? in reply to Just Plain Joe, 11-08-2006 17:18:40
You have to have the parts books for the 435 and the potential donor tractor. Depends on the individual part. No reason to make an alltogether different power steering system for the 435 than what's used on a 420/430. If the new parts can be ordered, use them. Do you want something with 46 years of wear on them if new can be had?
Just Plain Joe
11-10-2006 06:53:03
 Re: 435 PS worm gear thrust bearing source ? in reply to buickanddeere, 11-09-2006 19:07:22
If you read my original post carefully you would have noticed that I said that the parts are no longer available from John Deere. I'm not trying to save $15 here, just find out perhaps if there is some other source or substitute part available that somebody else might have come across. Where better to ask than a JD tractor forum? Somewhere in the world there is some application that used essentially the same one-directional, grooved face thrust bearing race, it's finding it that's the tough part.
8e3k0
11-10-2006 11:36:29
 Re: 435 PS worm gear thrust bearing source ? in reply to Just Plain Joe, 11-10-2006 06:53:03
Try John Shepard at 715 265 4988 or Dave Cook at 715 373 2092. They should have the used parts you are looking for. Ellis
