The DR stands for double run feed cups which yours should have. You move the cover inside box to open or cover large or small size cup depending on what you want to drill. "A" is the earlier version with curved box lids and there was later a DR-B with flat top box lid. They made similar R and other models too with flute feed cups. You have the wider frame EO model 20-10 and there was a narrower DR1610A made also. EO may also indicate different openers if you don't have disk openers and have hoe or hillside type instead. The lid charts are still available for most drills yet from JD as are the manuals. Looked after your post the other day and I only had manuals for narrow frame DR-A. You might find manuals on ads or ebay also. JD still list a manual that covers several instead of just DRA. The other manual is probably for narrow frame drill only? 800-522-7448 JD publications. Search JD publications for DR-A and will find..... Operator's Manual B, B-A, FB-B, DF-B, DR-A End Wheel Grain Drills OMM19333 English\ Spanish $40.00 Operators Manual CD-ROM B, B-A, FB-B, DF-B, DR-A End Wheel Grain Drills OMM19333CD English\ Spanish $30.00 Operator's Manual B, B-A, FB-B, DF-B, DR-A End-Wheel Grain Drills OMM18670 English $30.00 Operators Manual CD-ROM B, B-A, FB-B, DF-B, DR-A End-Wheel Grain Drills OMM18670CD English $30.00 Parts Catalog B-A, B-B, DF-B, DR-A, DR-B, FB-B End-Wheel Grain Drills PC822 English $30.00 Parts Catalog CD-ROM B-A, B-B, DF-B, DR-A, DR-B, FB-B End-Wheel Grain Drills PC822CD English $30.00
