1936 JD D
Farm W/Junk
11-08-2006 07:02:23
Hi I went to look at a 1936 D last week and had some questions. Im pretty familar with D tractors as I have a '36 and '29 currently. D's are my favorite. First off it has turning brakes. Were these an option in '36? Aftermarket? are they unusual? I did not hear it run as I was in a hurry to get home and cut beans but it does run but is currently dissassembled. What is it worth? Its on cutoffs. Everything is there, hood good fenders and platform need work drawbar looks brand new. The current owner is the 4th owner and originally came from 20 mins from his house. What is a estimate on price? Thanks
Matt
Farm W/Junk
11-08-2006 12:14:08
 Re: 1936 JD D in reply to Farm W/Junk, 11-08-2006 07:02:23
Hey the serial number is 125632 on that tractor. Which is before they were an option. Thanks for any more help.
Matt
JDMAN60
11-09-2006 04:04:40
 Re: 1936 JD D in reply to Farm W/Junk, 11-08-2006 12:14:08
Matt a little off topic but I have wondered how you came out on that old Hyster forklift you bought from me last year? What did you find wrong with it?
Glen in TX
11-08-2006 13:37:33
There were some earlier ones known to have turning brakes on them before the number stated in the parts book. It could also have been a tractor with parts off several others if you don't know all the history of it. Good point Brandon made about it should have cast centers on rear with those brakes as the hub centers served as drums also. It is not listed in the DI charts either so just a D with turning brakes.
WeirdDeere
11-08-2006 10:01:31
Glen covered it pretty well. Turning brakes were an option, and not a very common one. There is a slight possibility that it is a DI, see if you can get the serial number and post it.
However, it can't be on cutoffs AND have brakes, unless you mean the front wheels are cutoffs. The rear wheels would be cast iron.
I oouldn't give you a guess on the price...
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
Glen in TX
11-08-2006 08:46:21
Individual turning brakes were not common but yes were an option starting at 126089. Check the serial number real well as it could have been 1 of 42 DIs made in 36 but probably not a DI if was originally on steel and has cutoffs now. DIs were made from 35-41 but not all of them had turning brakes. Turning brakes could make it worth some more but not that much. You said drawbar doesn't look worn but is it the original drawbar? Sheet metal bent up on rear so it's been worked some or treated rough. Maybe or maybe not and insides could still be real worn out and cost more to fix. Look at how worn wheels might be on splines of axles or how loose steering is and that might tell you more. Just running doesn't mean anything either as it could still be worn out. If they have the rear trans cover off see if the large gears on axles almost touch the rear of case being 41 tooth gears used on most all ag tractors. DIs or D ag tractors could have gears changed to smaller 38,28, & 22 tooth gears. I had a 35 once that was used to road and run a thresher and someone had changed it to 28 tooth gears for a road gear of about 15 mph vs. 4 mph.
WyoDave
11-08-2006 09:07:05
 Re: 1936 JD D in reply to Glen in TX, 11-08-2006 08:46:21
Just out of curiosity how does a D feel going down the road at 15 mph. Everytime I drive one of ours it takes a couple minutes to get used to sitting so far back. Gotta love the D.
David
Glen in TX
11-08-2006 09:52:18
 Re: 1936 JD D in reply to WyoDave, 11-08-2006 09:07:05
It's different for sure and you don't want to go that fast on a rough road either. That tractor was good for nothing but parades now so sold it as didn't want to go to trouble changing gears. It's real hard to keep all the oil in from leaking on one too with smaller gears as you got to put more oil in trans. It actually ran slower when I had it on 28" & 18" rubber but I couldn't find 32" tires for the cutoff rims they had on rear but had common 20" truck tires on front. Did you get all your corn cut or more pics of combine in field? Like the combine field pics.
WyoDave
11-08-2006 10:02:49
 Re: 1936 JD D in reply to Glen in TX, 11-08-2006 09:52:18
I finished combining yesterday actually, but I didn't get any more pictures. In fact I don't know where my digital camera is at the moment, probably in one of the tractors or trucks. Now with the hay up, corn combined, cows out to pasture I'm on the winter schedule of substitute teaching when they need me, and working on tractors. Got a 70D standard that I'm fixing on now.
David
Glen in TX
11-08-2006 16:24:06
 Re: 1936 JD D in reply to WyoDave, 11-08-2006 10:02:49
That should keep you out of trouble lol. Harvest of corn, milo, and cotton just starting good here after hard freezes last week and indian summer this week.
Jak
11-08-2006 09:30:27
Don't know Dave I have never been on one past 6 mph myself.I seen one with the pto and parking brake a couple days ago and I wouldn't want to be in the seat when whatever I was pulling broke a driveshaft.Also how are you supposed to reach the parking brake if you are on a hill and need to park?I like them though.Jack(TN).
