Gas cap safety problem
Duane Larson
11-07-2006 21:10:01
Today we were plowing Iowa cornstalks with a '41 G pulling a 55AB 3-14 plow and a '44 A pulling a 44 2-14 plow. After we quit for the day the A tractor was idling to cool down prior to shutting down. When the cap was removed on the A fuel tank to check the gas level, liquid gas came splashing out of the gas filler tube, shooting 6-8 inches above the hood and splashing back down on the hood. This kept happening for better than 30 seconds, thoroughly wetting the hood with gasoline. Pretty scary! Apparently the gasoline in the tank had become hot enough to boil, and the cap did not relieve the pressure. The cap appeared to be original, but the gasket inside the cap had been replaced. Comparing the gaskets in the two caps on the '41 G, we found those gaskets did not go to the outer edge of the fuel cap, but there was about 1/8" clearance around the outer edge. Gaskets on the '44 A had a larger OD and left no space at the outer edge of the cap.
Looking at the cap venting, it appears there are two slotted holes near the center of the fastening part of the cap when viewed from the bottom, and a small hole near the outer edge which appears to be connected to the slotted vent holes and allows the tank to vent around the threads of the tank where it screws on. The larger gasket had sealed this outer vent hole and resulted in a pressure buildup in the tank. The older gaskets in the G caps provided room for the outside vent hole to function and there was no pressure buildup in the G. It may be prudent to check these gaskets prior to working tractors hard enough to heat fuel tanks up.
We had a good time plowing, and fortunately there were no sparks or the whole thing may have gone up in smoke. A real surprise! We have modified the A gaskets and will check tomorrow for pressure buildup.
Duane Larson
11-08-2006 18:42:46
 Re: Gas cap safety problem in reply to Duane Larson, 11-07-2006 21:10:01
Thanks to everyone for their comments - we finished plowing today and pulled the gasket out of the A cap. While the plowing time was less there was no pressure buildup, even in 75 deg weather (how can this be - 75 deg in Iowa in Nov?) We also realized we did not have a fire extinguisher in either vehicle. Indeed, we were lucky! I've boiled gasoline in my GP in the past but not in a later model with more clearance for air to flow around the fuel tank.
Earl, you need to pick your plowing days more carefully - I'll bet it will be nice and warm in Illinois tomorrow :)
Earl-IL
11-08-2006 20:35:44
 Re: Gas cap safety problem in reply to Duane Larson, 11-08-2006 18:42:46
Duane, We had our 9 th annual plow days last Sat. 40 plus tractors showed up.Best count we had 29 in the field plowing at the same time. We turned 97 acres for the host. He served a great lunch for all. Earl
Earl- IL
11-08-2006 11:42:21
Hi Duane, We have some success with using that thin alum insulating material between the tank and the heat shield. You also need to increase the size of the vent holes. We are going to build heat shield above the manifold & around the exhaust pipe Tractor pulling & plowing really builds heat. We have more problems with the 10 % ethanol fuel. The hot fuel creates some power loss. We plowed last week in 35-40 deg weather I had to keep the curtain down 1/2 way to keep my 1935 "A" Johnny warm. LOL Earl
machinery-man
11-08-2006 09:47:11
Another area of concern is checking a flooding tractor. A few years ago, was at garage, 530 was flooded and man took out plugs, when he turned over the engine he was doused with gas, good that he didn"t get a spark at the same time, he"d gone up in flames. Be cautious on the fuel situation. Only thing that helps is poor fuel quality of the day.
Carl NY
11-08-2006 07:54:48
Duane, the reproduction gas caps I had were made with a rubber gasket that was wider than the original stlye and closed off the vent holes. I removed the gasket and using a leather punch, made several holes towards the outer side. The new cap was installed before making the holes and the tractor would shut off after a few minutes of running. The extra holes solved the problem without gas leaking out.
Mike Aylward
11-08-2006 06:10:33
Duane, I've plowed many an acre with two-cylinder tractors in my time. A late A tractor WITH the heat shield will sometimes boil the gas in the tank while plowing in warmer weather. An earlier styled A WITHOUT the heat shield would allow this to happen even faster. I have stopped for noon a lot of times and could feel and hear the gas in the tank boiling. An A tractor needs to be idled for several minutes to allow it to cool before checking the fuel level. Even if the gasket and vent were functioning properly the boiling gas causes all kinds of potential trouble. The gas cap gasket may indeed be bad but you folks dodged a big bullet there. I have seen many A's in salvage yards that were burned due to what could have happened to you folks. Glad nobody got hurt. Mike
Mike Aylward...one more t
11-08-2006 06:13:45
 Re: Gas cap safety problem in reply to Mike Aylward, 11-08-2006 06:10:33
I'll add to my previous post to remind folks to NEVER open the gas cap on a hot tractor. Go to lunch, bring back some gas (you will need it anyway) and DO NOT TRY TO CHECK THE FUEL LEVEL UNTIL THE TRACTOR IS COOL. Once again, I'm glad nobody got hurt. I've been sprayed by hot gas trying to do exactly what was done here and realized it could have been MUCH worse. Mike
dan hill
11-17-2006 04:18:44
 Re: Gas cap safety problem in reply to Mike Aylward...one more t, 11-08-2006 06:13:45
All gas caps should be checked for plugged vent passages.It is generally thought that a vacuum lock will stop gas flow, not so.Hot gas will pressure feed the carb.The is no reason to check gas or refill when the engine is hot.Check fuel level before starting the tractor.
RalphinWI
11-07-2006 21:43:53
A question - Is it possible to fit a heat shield from a later A to these tractors when they are converted to the higher compression? I am currently working on one of the last slant-dash A's and have put in the higher compression pistons.
Glen in TX
11-07-2006 21:27:46
Good safety point Duane. Were these aftermarket caps with the rubber gaskets or the fibre gaskets? I've seen it happen with those with rubber gaskets expanding too much closing off vent holes. Not good for sure.
Duane Larson
11-08-2006 05:58:57
 Re: Gas cap safety problem in reply to Glen in TX, 11-07-2006 21:27:46
The caps on both tractors appeared to be original, as well as the G gaskets. The A gaskets were a cork/rubber composite and looked new. When I get home I'm going to check my gaskets and caps, for sure.
Glen in TX
11-08-2006 08:22:26
 Re: Gas cap safety problem in reply to Duane Larson, 11-08-2006 05:58:57
Just glad no one got hurt as well. Just seems I'd seen the gaskets covering vents too much on aftermarket caps and they needed punched like mentioned above to work but I went back to the fibre gaskets I could get from JD and some of those are almost too large so can't be too careful checking any of them. They sold non vented caps in same style from like a 6600 diesel combine that will fit and I've seen some use those by mistake too and most of those were originally for diesel tanks that had a seperate vent.
DickD
11-08-2006 07:25:24
Duane; I read about your experience with the fuel cap. Thank God it was no worse than it was. This brought to mind a tractor that came to a show at Winamac IN one year at which a participant had a styled "A" with unpainted gas and fuel caps. He was very adamant that the tractor had come out that way. I thought maybe painting the cap might have some bearing on the vent in it??
