720 muffler
motorstuff
11-07-2006 19:58:16
Why are the 720 mufflers dented? Also, which way is the dent supposed to face when installed? Thanks.
Glen in TX
11-08-2006 16:59:58
 Re: 720 muffler in reply to motorstuff, 11-07-2006 19:58:16
K&K tractor is one supplier of several that has the correct ones with no dent I believe. The aftermarket DR-3 Stanley muffler everyone else has fits them all A-720 and has the dent in it.
buickanddeere
11-08-2006 06:40:01
It's perfectly legal and kosher to retrofit a 30 series silencer muffler on to a 20 or early numbered series two cylinder. JD had a accessory parts book that listed all the part numbers and applications.
Mike Aylward
11-07-2006 20:22:24
Motorstuff, the original 720 muffler was not dented. Sadly, a lot of the aftermarket mufflers (that don"t look right anyway) have the dent. They are a "one size fits all" muffler and are really not appropriate for originality on any of the applications they are suggested for. The dent is for the A tractors but these mufflers are about 3 inches too tall for them. The tractors that used the taller muffler did not need the dent. While they will work, they are not original. Hope this helps. Mike
motorstuff
11-07-2006 21:49:25
 Re: 720 muffler in reply to Mike Aylward, 11-07-2006 20:22:24
Mike,
Thanks for the reply. I spent a bunch of time trying to take the dent out of my muffler thinking my dad had bent it on something. Then I went to the farm store and found the new mufflers were dented also. You say the 720 didn't need the dent. Was the A muffler intentially dented for a reason?
CLW
11-07-2006 22:44:02
 Re: 720 muffler in reply to motorstuff, 11-07-2006 21:49:25
The A muffler had to have a dent becouse it mounted under the hood and the steering shaft would not clear the muffler so the dent was put in so it would. The B was the same way. Starting with the first numbered series the muffler was moved up above the hood and the steering shaft no longer came into play. There are ads in GM and 2-Cyl. that sell the muffler without the dent.
