2040 Clutch - Need help
Don H in Troy
11-07-2006 19:31:19
Had to move my 2040 that had been sitting for 3 or 4 months. The clutch would not engage and had trouble getting it in gear. Then after I got it in gear and moving, pushing the clutch pedal did nothing. I kept on going. Where should I start? Hydralic fluid is a little low. That's about all I can see wrong. Need some suggestions on how to trouble shoot. The linkage from the pedal to the case is intact.
Tx Jim
11-08-2006 03:41:35
 Re: 2040 Clutch - Need help in reply to Don H in Troy, 11-07-2006 19:31:19
Hydraulics have zero to do with clutch no operating. Clutch is probably stuck to flywheel from sitting. Start tractor while moving in open area, stomp each brake pedal while holding down clutch pedal. If this doesn't work a split is next. If you get it free I would suggest blocking down clutch pedal for prolonged non use. Tx Jim
D. Hetz
11-09-2006 15:01:33
 Re: 2040 Clutch - Need help in reply to Tx Jim, 11-08-2006 03:41:35
Jim, thanks for the quick reply. I'll give it a try this weekend. In the mean time, is there a good site to get some repair manuals or instructions to agument the help from this forum. DH.
