JD 60 Steering Locked Up
Jamie Lord
11-07-2006 18:17:02
The steering on my JD 60 locked up suddenly and will not turn right. It has power not manual steering.
Has this happened to anyone else?
F-I-T
11-08-2006 08:03:07
 Re: JD 60 Steering Locked Up in reply to Jamie Lord, 11-07-2006 18:17:02
Jamie:
It's not uncommon for this to occur on an older unit that has some time and wear on it. What has most likely happened is the acutator valve, which is pushed forward or pulled back by the sliding action of the 1/4" dowel pins up and down the cam face are caught against a worn step on the cam, and now the valve is stuck in the "push oil against the right side of the rotary cylinder to turn wheels left" mode.
If you want to achieve a permanent repair, you will probably have to to remove the actuating valve assembly and rebuild whatever is worn. Be aware that those parts can get pricey, and any work in there has to be done well or you could risk the wheels turning hard right or left abruptly, and if you are flying along in road gear, it could throw you off, and the tumbling tractor on top of you.
The I&T manual actually does a pretty good job of describing the procedure. Read it several times until you can draw a diagram of the mechanism by hand. Then take it apart carefully, and keep everything in order. There are a couple of adjustments where you should use a dial indicator, but the rest just depends on clean conditions.
If you want to look more deeply into it, post back and we can work through it step by step, but it will take quite a bit of writing.
Frank
Jamie Lord
11-08-2006 09:01:22
 Re: JD 60 Steering Locked Up in reply to F-I-T, 11-08-2006 08:03:07
Frank,
Thanks for the reply.
After I posted the request I searched the JD forum for steering lock up. I found a lot of info. A lot of it was by posted by you. I have the repair manual and spent the morning studying up on the problem.
I will have a couple of questions for you later. Particularly on getting the valve housing remounted and adjusted. I've already scribed lines on all 4 sides of it to match back up when I remount it.
It's the grinding the screwdriver trick that the manual says to do in that position that has me kinda puzzled. I cleaned the grease out and there is a small round hole in the bottom. Is this the one they are talking about? If so, when I removed the large allen set screw and there is only a little nub on the back side. Is it just a really small set screw?
I be back later. More to come.
F-I-T
11-08-2006 10:55:38
 Re: JD 60 Steering Locked Up in reply to Jamie Lord, 11-08-2006 09:01:22
Great idea. Marking the position of that housing will get you very close when you re-start.
Okay, there was a change during the -20 series that many, many 60 and 70 owners had retrofitted to their units, so this might be the case where you'll have to see a portion of the 620 or 720 manual. I have those two pages scanned and will be happy to send them to you. Just shoot me an e-mail at [email protected]
If you can post any pictures of the front of the actuator valve it will help to identify what status your parts are - production or upgraded. I can't recall the "grind the screwdriver" section, and I'm on the road away from my manual so you have me at a disadvantage. I think that was part of the helix adjustment and that might not pertain to your '60' if it has upchange parts.
Maybe post back and describe the section of the manual in question. Also, does your tractor have the relief valve on the pump or on the actuator valve?
Frank
