1937 JD-B Tractor-Overdrive gear
Courtland
11-07-2006 12:11:21
1937 JD-B Tractor-Overdrive gear PN B407
How much if any, end play(left to right) or wobble should there be after installing a new bearing on the overdrive gear? Is most of the play taken up when the entire reduction gear assy. is installed?
New brgs have been installed on both ends of the countershaft & sliding gear shaft.
thanks
Mike M
11-07-2006 12:38:14
 Re: 1937 JD-B Tractor-Overdrive gear in reply to Courtland , 11-07-2006 12:11:21
I think the gear/shaft you are asking about the end play is controled by the bearing and snap rings in the reduction cover. The counter shaft is suspose to have some play I can't remember for sure .004-.007 ? but I take them down to no play.
Jen Jensen
11-08-2006 04:11:04
 Re: 1937 JD-B Tractor-Overdrive gear in reply to Mike M, 11-07-2006 12:38:14
Yes, that is our perception as well.
