AAAAAHHHHH!
Jak
11-07-2006 06:21:09
I forgot what it was like to hear an old D clickin them off.Went and worked on a 1929 D last night on the carburator.It was rusted up and hadn't ran in a year.We finally got her back together and what a flame out that short exaust at night.It's been a while since I have wrenched on a JD(been working on my Oliver puller)but it is indeed a pleasure.Now if I can find me another G.Jack(TN).
HaroldIHC
11-07-2006 20:51:41
 Re: AAAAAHHHHH! in reply to Jak, 11-07-2006 06:21:09
Hi Dick, Started tearing down a 29 D yesterday, #1 piston was stuck so we pulled the block,The rod and crank on # 1 looked perfect but # 2 rod was burned out. Dont know what to do with the old girl now. The flywheel was solid till I took the cap off # 1, then I could move it two inches. What would cause one rod to blow?---Harold
Jak
11-08-2006 09:35:11
 Re: AAAAAHHHHH! in reply to HaroldIHC, 11-07-2006 20:51:41
Sometimes the old oil filters will disentigrate because of water and a piece can flow through and stop up an oil hole.A frends G did this burning up number two rod.Bought another rod and blowed out all the oil passages and its been running ever since and that was over 10 years ago.
toot
11-08-2006 05:50:07
with the rods off, spin the flywheel and see if oil is getting to the rod journals, also check oil lines going to the main on that side. See also if the rod jornal passage on that side is dirty and obstructed. Kim Johnson in Cloquet, MN has a world of D parts, a rod should be no big deal to find.
DickD
11-07-2006 10:02:33
Jak; I know what you are saying. My friend and I were coming back from Indianapolis when we happened on a G working in the field. We pulled over and stopped to listen to it pull. The guy got up to us and stopped, and when we told him we were just listening to the tractor, he acted like we had taken leave of our senses! LOL
toot
11-07-2006 07:14:06
yeah you need to get back to the more well known green, lol.
Jak
11-07-2006 10:24:05
 Re: AAAAAHHHHH! in reply to toot, 11-07-2006 07:14:06
I know it Toot,should have had my head examined selling my last G.
