28 D
Butch 1 cow
11-07-2006 05:30:45
Where is the crancase vent on the older Ds. Mine had a makeshift vent on the oil fill cap, so I bought a good one on e-bay, but it has no vent at all. If I take the fill cap off whiles it's running, I get some vapors, but thats about all. Thanks Guys
Butch 1 cow
11-07-2006 10:44:14
 Re: 28 D in reply to Butch 1 cow, 11-07-2006 05:30:45
Thanks guys! I bought this D in '69, sold it in '71, bought it back last Feb. The engine is a little loose and I get some oil from both ends of the crank. Had it on my 4 roll New Idea corn shreader last week and hardly put a load on it. I'm sure it could use an overhaul just to take up the slack. I'll put the little cap back on instead on the modified unstyled A air stack that it's had for the last 40+ years.
Glen in TX
11-07-2006 10:14:31
Nope the old Ds didn't really have a vent per say and that's why some got oil leaks and sling it out the clutch or flywheel side if mains are worn some. I've seen many older Ds with makeshift breathers on the fill cap pipe or some have holes drilled at a angle in the pipe cap for a vent also. Later 31-38 unstyled D and styled D had a vent pipe from governor housing to the air cleaner intake manifold.
skip33652
11-07-2006 06:07:24
there wasn't one. I guess the deere engineers of the time decided there was no need . but dont worry that the crankcase will not explode or anything. there are air gaps in the oil slingers to let crankcase pressure out, it could also vent through the first reduction bearing into transmission and out through hole around the shifter shaft, as well as the wire used for the water injection. that now solves the question why an old d seems to slobber oil all over. Paul
