4010 turbo vs 4000
PJBROWN
11-06-2006 16:35:23
Any of you guys and girls know how the 4010 with turbo's stacked up against the JD 4000's. I know people used to add turbo's to 4010's
4010 pullr
11-06-2006 19:52:09
 Re: 4010 turbo vs 4000 in reply to PJBROWN, 11-06-2006 16:35:23
I have a 4010 with the M & W turbo setup and a little injection pump work that dyno's 150+ with the fuel screw turned most of the way in. But the same potential is possible with the 4000.
jhill52
11-06-2006 18:00:22
A turboed 4010 had 100-110 hp where a 4000 is I think 80 hp. I think that says it all.
j cook (iowa)
11-07-2006 12:46:36
 Re: 4010 turbo vs 4000 in reply to jhill52, 11-06-2006 18:00:22
A 4000 is a minimum spec console type 4020. By minumum spec I mean that it is a cheaper version---hp wise they have 97hp. The 4010 was the EARLIER version, of the 4020. predating the 88hp 1964 4020 AND the 95hp 1967 4020. The 96hp 1969 4020 is therefore three generations newer than the 4010.
Wanting to turbo a 4010 seems pointless. They are now a possible 46 years old, and unless on wants to use his 4010 for tractor pulling purposes, a 4520 or a 4320 both make a lot more sense for a "using tractor". Either the 4520 or the 4320 would be priced not all that much more than a "good" 4010, and they already are equipped with a turbo.
buickanddeere
11-06-2006 18:46:56
4000 has the exact same HP as a 4020 of the same production year and same fuel type. The 4000/4020 are a more advanced, de-bugged and robust tractor than the 4010. If you want more power in a 20 series tractor. Find a 4320, they go cheap.
Richard E.
11-12-2006 06:00:16
 Re: 4010 turbo vs 4000 in reply to buickanddeere, 11-06-2006 18:46:56
I was told that a 4000 was a 4010 with a 4020 engine. The 4020"s had heavier rear ends(axles and bearings) therefore more horsepower could spell trouble down the line. I"m not too sure if the turbo would make the engine more fuel efficient or last as long without it ? My 2 cents.
msb
11-07-2006 06:01:25
Unless you are into tractor pulling or just plain(well I won't say it) listen to buickanddeere.He is giving the best advice he possibly could.Buy a tractor that was designed for the extra horsepower and won't self distruct in the process of normal use.
