JD 400 backhoe squirting injector pump
BillinMass
11-06-2006 12:50:00
I have a 1970 JD 400 hoe and it is squirting diesel from out of the banjo fittings on the injector pump. One machanic tells me we need to get a rebuilt injector pump. I am not so sure. I think that I just need to stop the leaks. the tractor runs fine and the pump is pumping....what do you folks think?
Thanks in advance!
Mike M
11-07-2006 07:06:17
 Re: JD 400 backhoe squirting injector pump in reply to BillinMass, 11-06-2006 12:50:00
Might even be as simple as tightening them up ???
Roy Suomi
11-06-2006 16:17:57
If we're sure it's the banjo fittings on the injector lines..Go to Deere and buy some new steel sealing rings and change them....Why does the mechanic want to rebuild the pump???? Does he see something you don't see????..Don't use your hand to check fuel leaks around the injector lines...The fine spray can penetrate your skin and cause serious infection...I use a small piece of cardboard for this....
jdemaris
11-06-2006 16:16:43
Just blow the dirt off and put new banjo-washers in. If the new ones don't fix it - then there is probably a scratch on the line or the pump. In that case, use brass washers instead. It's not uncommon for that type of leak to occur.
