4620 john deere
ray 10
11-06-2006 08:18:01
tractor black smokes under load
buickanddeere
11-06-2006 18:49:50
 Re: 4620 john deere in reply to ray 10, 11-06-2006 08:18:01
When the exhaust is viewed againt a backdrop of green trees in particular. The 4020/4620 would show visible exhaust even at light loads. Tis the nature of the beast.
Dave in Tx
11-06-2006 16:37:04
need to check also that turbo is running, they will smoke bigtime if something is wrong with turbo
John Jenkins
11-06-2006 09:00:32
Check and clean or replace your air filter first.
Glen in TX
11-06-2006 08:41:34
That doesn't tell us much? Many of them could smoke when new if overloaded. What are you trying to pull? Cleaned the air filter lately? Someone turned pump way up for pulling? History of tractor?
ray 10
11-06-2006 09:19:59
 Re: 4620 john deere in reply to Glen in TX, 11-06-2006 08:41:34
I replaced the air filter. I have a 14' bushog on the tractor now and in high grass it really smokes I was told that the pump was turned up. Should I have the injector checked before the pump?
Glen in TX
11-06-2006 09:30:45
 Re: 4620 john deere in reply to ray 10, 11-06-2006 09:19:59
You may want to see if local mechanics or dealer mechanic can help you turn pump back down first. It just depends on how many hours and how worn engine is if it will clean up smoke too but yeah you eventually may need to pull injectors and clean them too but I'd try other things first before having to pull pump and injectors. Make sure none of the piping or hoses from air cleaner to intake manifold are leaking or cracked either since you are shredding in lots of dust probably.
Bob
11-06-2006 12:09:47
 Re: 4620 john deere in reply to Glen in TX, 11-06-2006 09:30:45
Glen,
Not to argue with you, but even IF the pump has been turned up, why would that make for MORE smoke at light load, such as the rotary cutter?
Cranking the pump up would make more smoke when it was pulling it's guts out, at maximum fuel rate.
At ligh load, it wouldn't be up against the maximum fuel rate stop, anyway.
Glen in TX
11-06-2006 15:13:51
 Re: 4620 john deere in reply to Bob, 11-06-2006 12:09:47
Bob, I read his first post to say under load. That to me meant loading the engine making it smoke at high RPM. Darn sure wouldn't consider a 14 ft. a light load in heavy brush on a older tractor that could have lots of hours and wear on it and they are going to smoke some especially if pump was turned up. Not seeing it or knowing more it may just be worn out or too much load for old tractor? A 4620 in good shape should sure handle the 14 ft. though without smoking like a freight train. He has something wrong or going on to make it do that. Some of the older 404s with turbos seemed to smoke more too when trying to get too much out of them. They just weren't as efficient as some of the later 466 engines. I know one year when we had 5010 break down and in shop all summer and they turned up our 4320 it sure did smoke more till turning it back down later. We spun off a good set of tires on it that summer trying to do the 5010s job too. That 4620 is intercooled too isn't it? He may need to make sure intercooler is all plugged up and clear also ?
ray 10
11-06-2006 09:35:32
Thanks for this information.
