JD 39B flywheel
Kevin Daniels
11-04-2006 18:48:13
Is there a special wrench to hand-crank an electric start 39-40 JD B? Is it the same as the wrench used to remove the flywheel?
Duane Larson
11-05-2006 20:45:16
 Re: JD 39B flywheel in reply to Kevin Daniels, 11-04-2006 18:48:13
Kevin,
The flywheel came with a casting bolted onto the center of the flywheel which had a center hole and two ramped notches to accept a stub with a pin in one end to catch the notches and a tapered spline on the other end to match the center of the steering wheel. If cranking needed to be done, the steering wheel was removed, the stub stuck in the steering wheel and the other end inserted in the flywheel, and the engine turned over by spinning the steering wheel. When the tractor started, the ramped part of the notches in the center casting pushed the steering wheel/stub assembly away from the flywheel.
The stub is only about 3" long, and came in the toolbox of tractors with electric start. The wrench used to remove the flywheel will not work. The stubs show up on eBay. The starting process described here should be in your owners manual for your B, along with pix of the stub and the process.
bm3501466
11-04-2006 19:05:00
I thought they had a removable steering wheel for those models to put on the flywheel to crank it. I may be wrong, but someone showed me that before.
JDSam45
11-04-2006 19:04:26
Usually, you removed the steering wheel and it fits in a cover over the crank shaft, bolted to the flywheel, that is slotted to receive the steering wheel splines.
Kevin Daniels
11-04-2006 20:27:19
 Re: JD 39B flywheel in reply to JDSam45, 11-04-2006 19:04:26
So the steering wheel should have some sort of notches on it to fit in the slots on the flywheel?
James Howell
11-06-2006 16:51:47
 Re: JD 39B flywheel in reply to Kevin Daniels, 11-04-2006 20:27:19
Take a look at item 220046032953 on eBay. Listed as John Deere Starting Hand Crank Adapter w/Steering Wheel.
Kevin Daniels
11-08-2006 09:49:13
 Re: JD 39B flywheel in reply to James Howell, 11-06-2006 16:51:47
Thanks for the info!
Ken Thies
11-05-2006 20:50:52
No you need the stub shaft with the pin on one end and the other shaped to fit into the steeringwheel.
Read above post.
Ken Thies
