48A Crankshaft regrind?
Sam S.
11-04-2006 18:28:56
Can my CrankShaft from my 48A be salvaged? Spec's call for the crankpin(Connecting Rod?) to be 2.998" - 3.000". Mine came in at 2.969" on the left and 2.977 on the right side. The smaller left side is pretty scuffed up and got hot. The connecting rods are I believe babbeted, with no inserts.
I know there are 0.010" and 0.020" undersize bearings, but these are still not enough and my crankshaft cannot use inserts anyway.
What are my options?
Thanks, Sam
Mike M
11-06-2006 05:33:03
 Re: 48A Crankshaft regrind? in reply to Sam S., 11-04-2006 18:28:56
Any GOOD crankshaft shop can normally build them back up. But if your splines are bad on either or both ends I'd for sure look for a good used crank. The used one may be even cheaper than the grinding ? Babbit rods can be redone,or even remachined to accept insert bearings.
F-I-T
11-04-2006 19:15:07
During the wars years when spare parts were tough to get, Deere recommended extending the life of undersized crankshafts by spray welding and regrinding. It was detailed in a service bulletin. Anyway, a good machine shop that provides spray weld repair can best answer your question. It doesn't cost much to ask.
Frank
Sam S.
11-06-2006 03:09:57
 Re: 48A Crankshaft regrind? in reply to F-I-T, 11-04-2006 19:15:07
Frank,
Thanks for the response. Guess I have some phone calls to make.
Sam
Tim Brownlee
11-19-2006 09:25:52
 Re: 48A Crankshaft regrind? in reply to Sam S., 11-06-2006 03:09:57
Hello, you can send your crankshaft to someone such as Lunati or Chromecrankshaft co. who can build the journals up with hard chrome then be turned back to size. Alot of auto racers use this procedure as well as I and it makes your crank practically new.
Thanks
Tcb
PS-I have a 1948 A John Deere too-just got it.
