B HYDRAULIC LIFT
ZANE
11-04-2006 18:00:26
The lift on my B doesn't want to work. I took the pump off and inspected it and also the control mechanism from the top rear of the lift. Also removed the whole rear cover to see if all seemed to be assembled as it should be. I can't see anything wrong. I filled the drive line with 90 and filled the top where the control rod enters from the two pedals for the lift. Nothing seems to be happening. The PTO is in gear and turning. The pedals seem to snap but the lift will not come up I can force it down and it feels like it has air in the cylinder but it will not lift up.
Can someone tell me how the lift is supposed to work and what may be happening with mine on the B? It is a 1937 model.
Thanks, Zane
buckeye al
11-06-2006 11:08:54
 Re: B HYDRAULIC LIFT in reply to ZANE, 11-04-2006 18:00:26
If it does not raise and when you push the rockshaft in the downward direction and it feels like it has air in it, that indicates that the shaft is partially raised and that the valve is still closed.
There is a cam inside that works off of a ratchet and a pin. If that cam (or the valve spool) stops partway between the lift position and the drop position so that the ratchet can't grab it & rotate it to the next step, the mechainsm is "stuck". There is a pin inside that stops rotation of the cam, holding it in the lifting position until the crank arm on the rockshaft hits this pin. At that point the cam is released to rotate and move the operating valve to the idle (open center) position but if it doesn't get quite all the way there, the ratchet can't grab the cam so you can't make it go to the drop position.
On rare occasions, you can rotate the rockshaft in the raise direction to bump and the stop pin releasing the cam which will allow the system to go to the next phase or cycle. It's rare but it may help.
Ohterwise.....
Drain & remove the power lift valve from the rear of the rockshaft housing. Make sure of which bolt has the copper washer on it & keep it in that particular bolt hole when you put it back or it will leak oil.
Either the cam is in the wrong position and stuck or the ratchet dog is not functioning and can't grab it then force it to the next mode. Either fix requires removal of the valve body for inspection. Removal of the body does not reveal any surprises.
Good luck.
ZANE
11-07-2006 04:37:12
 Re: B HYDRAULIC LIFT in reply to buckeye al, 11-06-2006 11:08:54
When I took the pump off to inspect it there didn't seem to be any seal internally to prevent the oil leaking out of the top reservoir. Shouldn't there be one there? All I could see looked like a couple of brass bushings that the PTO rides on. The rear seal looks to be a packing with a packing nut.
On my lift there doesn't seem to be a full plug half way up the top reservoir/valve body? There is a round thingy that I tried to move with a pipe wrench but it didn't budge with the moderate effort I gave it. What is that? Pressure relief valve?
Would you please email me if you can help.
Thanks for any help.
Zane
Ford 312
11-04-2006 20:11:26
As I understand you are using 90 weight oil. It should be filled with same weight of oil as engine. I use 30w engine oil in my JD B lift.
ZANE
11-06-2006 05:44:03
 Re: B HYDRAULIC LIFT in reply to Ford 312, 11-04-2006 20:11:26
That alone should not cause it to not work at all.
I am pretty educated on hydraulics but this one is so different than other hydraulics it has me baffled.
Do you know how it works or where I can find information on it?
Zane
Ford 312
11-06-2006 06:35:02
 Re: B HYDRAULIC LIFT in reply to ZANE, 11-06-2006 05:44:03
From your description, I gather that it is a JD power lift and not a power-trol, is that right? The power lift has an adjustment screw at the bottom of the housing below the fill cap. Don't know if improper adjustment of that screw would keep it from working or not. If it is a power-trol the plugs are different for rock shaft use, than the plugs used for a remote cylinder. Rock shaft will not work with the wrong plugs. Also, I have read there is a gasket somewhere that can leak and keep the system from working. Sorry, I really don't know too much about the system. Hoepfully someone will come on who can give you better information.
