1010 Diesel
Brian in NE
11-04-2006 17:30:07
Hi folks, I normally read the IH and pulling
boards, But I have a question about a 1010 diesel that I have been working on for a friend. I have overhauled the engine on this tractor and am having a dickens of a time getting the pump timed correctly to the engine. The engine has timing marks for both the gas (26 BTDC) and the diesel (TDC). I can only get the pump to time up on the gas timing mark. I have rechecked the injection pump, camshaft number, oil pump drive gear and looked up at the crank and cam gears with a mirror and light to check their timing as far as I can tell every thing checks out. What am I missing? Thanks ahead of time.
jdemaris
11-04-2006 17:54:11
 Oil pump is out of time in reply to Brian in NE, 11-04-2006 17:30:07
I guess I don't understand the problem unless you had the engine oil pump out. When the flywheel mark is at TDC, and the lines are lined up in the injection pump, it is in time. If you cannot get them lined up, then the engine oil pump is out of time with the camshaft. With the injection pump off - and looking into the drive-hole where the top end of the oil pump is . . . and the engine is on TDC for #1 cylinder on it's compression stroke - the drive-slot is supposed to be 45 degrees from parallel with the crankshaft and the little dimple mark pointing towards #4 cylinder. If the slot is not pointing the way described, the oil-pump has been put in wrong. It will need to be slipped out, and the drive-gear rotated a little, and stuck back in properly. If this was a gas engine, you could just pull the plug wires out of the cap and relocate them. That won't work with steel diesel lines though.
