A gasket for fuel sediment bowl
Sam F.
11-04-2006 15:45:11
Does anybody know the NAPA number for the fuel sediment bowl gasket ?? Model A. The neoprene type. Thanks
Sam F.
11-06-2006 07:26:13
 Re: A gasket for fuel sediment bowl in reply to Sam F., 11-04-2006 15:45:11
I was hoping to get the number for a NAPA gasket. I have a Ford 9N amd they make one for it made of neoprene and it seals each and every time PERFECT. Thanks
Sam#3
11-06-2006 05:51:25
They're a generic item. Measure your old one or the bowl and get two and two filters of the size you need. I say two because you always need a spare.
Henry M
11-06-2006 01:46:03
Mother Deere's gasket for that application may be cork. That is where I get mine for the 420 and keep a spare on board. The last time I took the bowl off the thing would not reseal and I had to get into the reserve stock.
Tim S. Montesano
11-12-2006 17:46:09
 Re: A gasket for fuel sediment bowl in reply to Henry M, 11-06-2006 01:46:03
Get a can of EZ TURN Lubricant (Fuelube} and you can use your existing cork over and over again for years to come. A little dab of this stuff will seal any potential fuel leak problem areas. Put it on sedivent bowl valves and they will seal perfectly and be a breeze to turn of and on for years. I use it all the time and any fuel connection, gasket or valve. It is a kind of an off-white heavy sap like paste or goo. Can be pruchased from Aircraft Spruce & Specialty Co. Can be found on the net at {www.aircraftspruce.com). Try this and your troubles will be over.
730jd
11-04-2006 16:54:34
Try looking at Deerly departeds web site. They have things like what you need.
Deano
May be easier
11-04-2006 19:21:12
 Re: A gasket for fuel sediment bowl in reply to 730jd, 11-04-2006 16:54:34
Doesn't Deere still sell them. Pretty sure TSC or Farm and Fleet type places have them too...
