70 Diesel fan shaft
billyiron
11-04-2006 18:14:21
just got home a 70 D,and discovered the fan shaft aint turning,,spins free as a bird,this is a power steering model,,any clues out there? thanks billy
F-I-T
11-04-2006 19:34:40
 Re: 70 Diesel fan shaft in reply to billyiron, 11-04-2006 18:14:21
The power steering models drive from the governor shaft bevel gear to the fan shaft bevel gear on a shrot stub shaft next through one splined coupling through a longer shaft upto another splined coupling that drives the final shaft, which is in the power steering pump. So, you have two gears full of teeth, two splined couplings, and three shafts counting the stub shaft at the front of the governor that can be the cause. I hope it's just the short shaft or one of the couplings. The gears and the P/S pump are pretty expensive. At lwast if it will free wheel the pump is not likely tied up.
Frank
