5303 wheel widths
5303
11-04-2006 17:56:32
I need some farmers out there to help a new one. Is there one wheel width setting, to plow, disk, seed, cut, bale, I have a new 5303 and it is 55 inches to the centerline. Also after determining, the rear is the front set out farther? thank- you all.
wilamayb
11-05-2006 04:57:44
 Re: 5303 wheel widths in reply to 5303, 11-04-2006 17:56:32
There are actually sevral postions available by truning the dish of the wheel around, or placing the rim on the inside or outside of the center wheel disc. Of course if you want to change the way the wheels are dished it would be most easily accomplished by swapping sides with the whole wheel, rim, and tire combination. This should all be explained in your operators manual. If you dont have one it would for sure be in your best interest to get one.
5303
11-05-2006 07:43:05
 Re: 5303 wheel widths in reply to wilamayb, 11-05-2006 04:57:44
thank-you Wilamayb, yes I have the owners manuel, and all the info. to turn the wheels dish in dish out ect. I am trying to find out what is the BEST overall width to set this tractor at and Leave it there, for general HAY farming.
wilamayb
11-04-2006 15:43:32
 Re: 5303 wheel widths in reply to 5303, 11-05-2006 07:43:05
If you're not row cropping why not set it as wide as possible for stability??
