730D Pup Engine
Fireman
11-04-2006 17:17:37
Am a rookie with pup engines,heres my problem.....motor turns over fine ,no spark @ plug either side,have sand blasted plugs clean,both points are opening.Where or what should I be looking at?
buckeye al
11-06-2006 11:16:58
 Re: 730D Pup Engine in reply to Fireman, 11-04-2006 17:17:37
Quick caution.... You know you have to test BOTH plugs in a bank at the same time don't you?
If you're looking for spark in one of the front bank plugs but the other front bank plug's wire is dangling in free space, neither plug will spark! Those plugs always spark in pairs because they're in series with each other.
You have to look for spark in BOTH plugs at the same time on a given bank!
F-I-T
11-04-2006 19:37:39
I agree with 720D. You can check that you have power to the points (battery voltage), and if you put a piece of paper between the one set of points, you can manually break the opposite set and try for spark without cranking. Just make sure the distributor cam is not lifting your test set of points. 100 ways to fry the coils and folks do it all the time. You didn't ever jump it with 12 volts, did ya? That way 101.
Frank
720Deere
11-04-2006 19:17:46
For lack of a better test, smell your coils. If they have a burnt electrical smell, there's a 99% chance that you need to drop $110 for a new pair of coils.
If the switch is left on without the motor running, it usually results in one or both coils being burnt up. It doesn't take long either.
