How do you get these B hubs off?
Turke Bros Farm
11-03-2006 10:55:18
I got a JD B, trying to get the tires off, the hubs are reversed so they have to come off first, before i can remove the tire, The locking taperlock is off, i just cant get it off the spline. HELP!!!
Paul from MI
11-04-2006 06:48:16
 Re: How do you get these B hubs off? in reply to Turke Bros Farms, 11-03-2006 10:55:18
If all you want to do is change tires, why take the wheels/rims off? It's easier to change the tire on the tractor & the weight of the itre helps putting the new one on. Once you have the bead broken loose the rest of the job is easy.
Good Luck,
Paul
DRL
11-04-2006 06:02:17
If you have the pressed steel rims, then you will have to remove the hubs, but if they are the cast centers with a blank rim, you do not have to remove the hubs. Unless you have cast centers from very early on, there should be a flat spot on the center right at the valve stem detent which will allow you to snake the blank rims off the centers.
DRL
11-04-2006 06:08:12
 Re: How do you get these B hubs off? in reply to DRL, 11-04-2006 06:02:17
Just re-read my post. If they have the pressed steel rims, unless the rims are bolted to the hubs on the inside (i.e. towards the tractor) just unbold the rims from the hub. Again, if you have the cast centers, you do not have to remove them in order to remove the rims/tires.
John T
11-04-2006 05:11:12
WE built a puller consisting of a one inch thick flat steel plate with 4 holes to match the holes in the hub and then used longgggg ggg 3/4 grade 8 bolts threaded into the wheel with back up nuts behind and then placed a porta power between the axle end and the puller plate and that did the trick fer sure.
John T
P Browning
11-04-2006 08:50:29
 Re: How do you get these B hubs off? in reply to John T, 11-04-2006 05:11:12
John -- there's no need for Grade 8 bolt stock in this application -- too costly. B-7 threaded rod from any reputable fastener place will do just fine, and it has greater tensile strength than grade 5 bolts.
P Browning
11-03-2006 14:13:22
When using a hydraulic jack as Mike outlined, you must have the operating cylinder of the jack DOWN so that the piston always has oil to pump. 'Won't do much otherwise! (PatB)
Mike M
11-03-2006 12:35:32
Do you have the pressed steel wheels ? (The kind without the big cast iron center) Either way for the hub you will need to have a large puller or make one up with some 3/4" all thread and screw it into the hub where the clamp ring bolts were ( I think the holes go all the way through ? ) and put a plate at the outer end so you can put a jack between the end of the axle and pull it off.
