450 CRAWLER TRACK ADJUSTING CYLINDERS
RON ATCHISON
11-02-2006 07:15:53
HI, I'M LOOKING FOR A PAIR OF REBUILT TRACK ADJUSTING CYL'S FOR MY OLD '72 450. THANKS FOR ANY HELP. PS..I'M NOT SURE WHERE TO POST THIS?
jdemaris
11-02-2006 11:41:51
 Re: 450 CRAWLER TRACK ADJUSTING CYLINDERS in reply to RON ATCHISON, 11-02-2006 07:15:53
I suggest you pull them apart first - unless money is not an issue here. Quite often, worn adjuster barrels work great when new style seals are installed. All the parts are available from Deere - but . . .
Many older 350s and 450s went though several types of seal revisions. The earliest two versions were thin rubber rings and would not hold once the cylinder got worn a bit. The third version is a hard neoprene type seal with a directional lip on it. I think it began to be used with the "C" series. They work great. In our Deere shop, with all the older 350s and 450s, we simple recut the groove in the piston to fit the newer seal on.
If you buy a thin old style seal and have some wear, you're wasting your time.
CFWelles
11-04-2006 03:33:30
 Re: 450 CRAWLER TRACK ADJUSTING CYLINDERS in reply to jdemaris, 11-02-2006 11:41:51
That's really good advice. I have a 350C that I have owned since 400 hours in 1980 and the machine is now part of me. Did the dirt work for my house and driveway, skidded a whole bunch of logs, worked it out when I was younger. Put a new cylinder kit in #2 about five years ago. Has been a wonderful little machine. I have cleaned up the cylinder adjusters once when I put in new lip seals as you mention and also cleaned up the push rods and used a body filler plastic applicator to apply a film of JB Weld to the pits. Then carefully sanded this down. This has kept the dirt and moisture out and they are still working like new after about 8 years. Good advice on regrooving to go to a lip seal. Replacement of these is absolutely unnecessary with a little ingenuity.
souNdguy
11-02-2006 08:12:30
Try contacting wengers of pa.. they have a huge salvage yard.
Soundguy
