Removing Battery Tray on 420U
Ken Reese
11-01-2006 17:05:33
The battery tray on my 1956 420U is rusting away and needs to be replaced.
I must remove four very rusted 1/4"X 3/4" cap screws in order to replace the tray.
I have been soaking them in penetrating fluid.
Quarter inch cap screws do not have much girth/body and I don't want to twist them off.
Heat may be the answer but the gas tank above is still in place.
Suggestions????
Thanks, Ken
Mike M
11-02-2006 06:21:46
 Re: Removing Battery Tray on 420U in reply to Ken Reese, 11-01-2006 17:05:33
Smack the heads of the bolts as hard with a BFH this gets their attention ! Then try loosening them and see if they move. They might not be too bad as they go into a sealed up hole.
Hayfarmer
11-01-2006 18:46:31
if it doesn't work as described below, not that hard to remove gas tank then you can get at the bolts to drill and tap
machinery-man
11-01-2006 18:19:54
see of you can get the tray out from under the bolts. You could cut with chisel, work out piece. Then get a good pair of vise grips. Secure and barely move back and forth, like slightly tapping. You would get the bolt to turn. Remember back and forth slightly.
