49 John Deere A Rod Bushings
green49jda
11-01-2006 11:44:55
Does anyone know how to remove the round bushings (bearings?) that are in the connecting rods on a 49 A JD? The bushings I want removed are the ones that the wrist pins run through on the pistons. Is there some kind of puller to remove them? I don't want to try anything unless I know the correct way to do it. Thanks.
Glen in TX
11-01-2006 18:31:52
 Re: 49 John Deere A Rod Bushings in reply to green49jda, 11-01-2006 11:44:55
They also made oversize wrist pins and you resize the holes in piston and rod bushing and sometimes don't even have to replace them. Otherwise just press them out but new ones may need resizing to fit pins you will use. No they didn't make a special puller.
DanL-Colorado-9N252085
11-01-2006 11:58:24
I'd just take them to a machine shop. They can replace the bushings, ream them to fit the pins, magnaflux them and check the rods for straightness while they have them.
My 1 Pence worth (I'm in England right now and the exchange rate is 2-1 or so, so that amounts to about 2 cents.) My advice is easily worth half that... -GRIN-
green49jda
11-01-2006 12:06:39
 Re: 49 John Deere A Rod Bushings in reply to DanL-Colorado-9N252085 , 11-01-2006 11:58:24
I want to know how to remove them..... ..
11-01-2006 22:36:46
 Re: 49 John Deere A Rod Bushings in reply to green49jda, 11-01-2006 12:06:39
Excuse me, sir.
Mike M
11-01-2006 13:05:33
You can use a press and something close to the dia. like a socket ? or cut through them with a hacksaw and pop them out,or I've also cut out brass bushings with a chisel round end with a V notch ground in it to cut through the bushing. Some of these may be brass and some steel backed ? and after being pressed back in should need resized.
