1020 3 cyl diesel
LLoyd in Conn
11-01-2006 10:39:27
where can I find some info on this tractor,did it have live power,what years was it porduced...wieght, HP that kind of info...
jdemaris
11-01-2006 12:15:24
 Re: 1020 3 cyl diesel in reply to LLoyd in Conn, 11-01-2006 10:39:27
Great tractor. In my opinion - the best utility tractor that Deere ever built. It was available with several options - ground driven PTO, two-stage clutch live PTO, hydraulic independent PTO, hydraulic hi-lo, hydraulic reverser, manual steering, power steering, etc. With the industrial version (yellow 300), a bigger hydraulic pump was available than with the 1020. The 820 and 830 Manheim tractors are almost the same. Engine is a 138 gas or a 152 diesel - same as used in the 350 crawlers, 380 forklifts, etc. It's around a 4800 lb. tractor and around 38 PTO horsepower. The 1020 shares absolutely nothing with the 1010 - they are ground-up totally different machines.
machinery-man
11-01-2006 10:58:47
The 1966 model I have has live power, 2 stage clutch, per book has 40 h.p. Is an excellent power to weight tractor. John Deere worked out the bugs by the 20 series.
