3020 hydraulic pump leaking
Illinois Farmal
10-31-2006 17:45:06
My 3020 NF gas is leaking hydraulic fluid from somewhere above the front wheels. I assume this is the hydraulic pump that is leaking but I can't seem to find where it is leaking from. The lines don't seem to be leaking anywhere. Are there any commom places that leak on these pumps and how difficult are they to repair? Thanks for any help.
jdemaris
10-31-2006 19:57:34
 Re: 3020 hydraulic pump leaking in reply to Illinois Farmall, 10-31-2006 17:45:06
As others have already said - there are many places to leak. But - with the pump itself - the piston plugs are common leakers. When the pump was new - all they had were o-rings for seals and Deere had a lot of trouble with them. Now, they are installed with teflon sheafs over the o-rings (since 1979). Also, the shaft seal - which is the #1 leaker. If it is leaking - the shaft is probably loose. The seal on the outside is a low-pressure oil and dust seal. Behind it and inside the pump is a square-sided o-ring and teflon backup washer that does the high-pressure sealing. To replace it, the pump must come out, be taken all apart, and main shaft removed. Also, the main shaft rides in adjustable cone and cup bearings that are adjusted with shims so the shaft only has .002" -.004" end play. When it gets looser than that, the seal won't hold.
Gerald J.
10-31-2006 18:27:27
There is an oil reservoir, an oil cooler, the pump, a control valve, and considerable plumbing up there. Any can leak. And its not unheard of for the pump case to crack. Just don't feel for squirting leaks with your fingers. Hydraulic oil isn't good for the body when injected deep.
And just above the wheels there is the power steering hydraulic motor that can leak too. It also has plumbing pipes and fittings.
Gerald J.
Bob
10-31-2006 18:18:40
There's quite a few things that can leak up under there, from the shaft seal, to the nylon weep line, to the steel lines, to the "O" rings on the 8 plugs over the individual pistons in the radial pump.
I have a 3020 in the shop right now that is leaking past 2 of the piston plugs.
It took 45 minutes with the hot water pressure washer to get things clean enough up there so I could see what was leaking!
francis pawelek
10-31-2006 18:02:22
if its like the 4010 wide front,then the hyd box has to come out or unless you can get to it with out pulling it,where the harmonic balancer hooks up to the pump with the 2 nylon bushings,the pump more than likely is in front of that and leaks a lot even when shutting down the tractor,but i believe the shaft has to come out ald replace the o-ring around it,let me know what else you find out but i think thats what it is more than anything,thats what i had to do to mine,but pull the wide front end off
gfs
10-31-2006 18:01:46
Sometimes it is hard to find a leak in the metal lines, I have had some of the hoses start leaking under the cooler. Also check and make sure that a line hasn't loosened, doesn't take much to cause the leak under pressure.
