730 JD Steering wheel play
motorstuff
10-31-2006 17:18:14
The steering wheel shaft has a lot of play in it where it goes into the dash casting. I am assuming the one or both of the bushings in the dash casting are shot.
Before I start, has anybody got any advice on what to do or not do? It looks to me like the wheel and shaft would come out if I loosen the first steering shaft universal joint
Thanks in advance
730jd
10-31-2006 18:08:24
 Re: 730 JD Steering wheel play in reply to motorstuff, 10-31-2006 17:18:14
Had the same problem with my 730 steering.
You can remove the universal joint from the shaft below the dash and remove the woodruff key from the shaft and pull it out the top. The bushings need replaceing and take the shaft to a machine shop and they can build it up and machine it down where it is worn at the bearing surfaces.
I done that with mine and it now works great.
Deano
motorstuff
10-31-2006 19:43:45
 Re: 730 JD Steering wheel play in reply to 730jd, 10-31-2006 18:08:24
Thanks for the reply. I haven't tried to find the bushings yet, but I hope I can get them from John Deere. Did you have to do anything to the bushings to get them to fit the shaft?
730jd
11-01-2006 12:12:32
 Re: 730 JD Steering wheel play in reply to motorstuff, 10-31-2006 19:43:45
The bushings are available from John Deere and not hard to install. Just drive them in from the top down.
Deano
CFWelles
11-05-2006 04:53:13
 Re: 730 JD Steering wheel play in reply to 730jd, 11-01-2006 12:12:32
Have you checked Deere on these recently? I thought they were unavailable when I rebuilt mine late last year. I ended up buying bronze bushings from a jobber with the correct OD and ID. Building up the shaft and turning down is the best way for sure. I had to try a cheaper route building up with JB weld and carefully filing and sanding down. Works fine and is tight, but probably will be wearing out soon unless the tractor is just for parade or show. I am working mine a little. Also, he may find the universals in rough shape. I know they are unavailable. I took mine apart, cleaned out cups with steel wool and reassembled with Lithium grease packed in using O rings for dust seals. The universals work well now.
