A and B sound different
Hig5060
10-31-2006 07:52:59
Hi guys! I have a 1944 B and a1950 a why do they sound different? The A has a lot more distinct popping sound than the B. I had to rebuild the B last winter and rebored the cyclinders cause of some bad streaks. I put .090 pistons in it and they were aluminum of course is this the reason? I haven't been in the A but it could still be cast iron pistons in it. Or is it just because the A pistons are bigger. Also the other day I started up the B and it had probally 2 spoons of water in each cyclinder, it had been sitting for about 2 months.This don,t sound good to me what do you all think? It blew out the petcocks when cranking its a hand crank of course. It has never done this before Thanks!
Hig5060
10-31-2006 16:54:32
 Re: A and B sound different in reply to Hig5060, 10-31-2006 07:52:59
Dickd No I didn't check the push rod tubes. Are you talking about in the head or cylinders or both? This was my first JD and I still got a lot to learn. I guess now its live with it or tear it back down right. I take it they are changeable. Thanks but it wasn't exactly what I wanted to hear
greenmech
10-31-2006 19:53:07
 Re: A and B sound different in reply to Hig5060, 10-31-2006 16:54:32
Push rod tubes are in the head, believe there are two in the 44 B. If these are leaking you will have water in the oil also. One way to check this is to park the tractor nose down hill and remove the valve cover, should see if it leaks. Ron Mn.
DickD
10-31-2006 10:50:46
You probably checked these when you had the engine down, but pushrod tubes can cause this problem also.
MikeinKy
10-31-2006 09:59:47
The B is a faster RPM engine.
greenmech
10-31-2006 09:20:55
If you continue getting water it could be a leaking head gasket or a craked head. Maybe the carb leaked some gas into the cylinders and thats what came out the petcocks.
francis pawelek
10-31-2006 08:34:42
i'd say because of the size of the motor it may be different,but then again if it blew out waterwhen it fired up,,it also fouled a plug which will kill a cylinder till you remove the plug and air it out,,
another way to see which cylinder is not running,while the tractor is idling,check which side is not as hot as the other side,thats a good way to check if the plug is fouled out too from fuel or water,later
B-maniac
10-31-2006 16:36:49
 Re: A and B sound different in reply to francis pawelek, 10-31-2006 08:34:42
Your "B" is 175 cu. inches and the "A" is over 300 if memory serves me right. Depending on the year of the "A",it may have a higher compression ratio than the "B". Bottom line is the A makes bigger bangs, even at the same rpm as the B it will sound more "muscular". Muffler size and construction will make a diff. too.
